Im 12C, VLR Jul wurde durch das VLR Hauptprogramm ersetzt. Damit ist VLR wieder in fast ganz DK zu empfangen.
Im 11A und sicher auch in den anderen Muxen ist Soft Jul ersatzlos abgeschaltet worden.
Ensemble: 0x9001 DK DAB1 [ DK DAB1 ] ECC: 0xE1, UTC 60 min, INT: 1, alarm announcements: 1 Services (18): 0x9091 BBC WorldService [ BBC WS ] ECC: 0xE1, Country: Denmark, PTy: News (static), Announcements: No AudioComponent (primary), SCIdS: 0, Label: 'BBC WorldService' [ 'BBC WS' ], ASCTy: 0x3F (AAC) SubChId: 1, Language: English, StartCU: 0, NumCU: 30, EEP 3-A, Coderate: 1/2, Bitrate: 40kbps UserApp 1/1: Label: '' [ '' ], UAType: 0x2 (SlideShow), X-PAD AppTy: 12, DSCTy: 0x3C (MOT), DG: 0, Data (2) [0C3C] 0x9092 r8Dio [ r8Dio ] ECC: 0xE1, Country: Denmark, PTy: Varied (static), Announcements: No AudioComponent (primary), SCIdS: 0, Label: 'r8Dio' [ 'r8Dio' ], ASCTy: 0x3F (AAC) SubChId: 2, Language: Danish, StartCU: 834, NumCU: 30, EEP 3-A, Coderate: 1/2, Bitrate: 40kbps UserApp 1/1: Label: '' [ '' ], UAType: 0x2 (SlideShow), X-PAD AppTy: 12, DSCTy: 0x3C (MOT), DG: 0, Data (2) [0C3C] 0x9094 *The Voice [ *Voice ] ECC: 0xE1, Country: Denmark, PTy: Pop Music (static), Announcements: No AudioComponent (primary), SCIdS: 0, Label: '*The Voice' [ '*Voice' ], ASCTy: 0x3F (AAC) SubChId: 4, Language: Danish, StartCU: 30, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps UserApp 1/1: Label: '' [ '' ], UAType: 0x2 (SlideShow), X-PAD AppTy: 12, DSCTy: 0x3C (MOT), DG: 0, Data (2) [0C3C] 0x9095 *myROCK [ *myROCK ] ECC: 0xE1, Country: Denmark, PTy: Rock Music (static), Announcements: No AudioComponent (primary), SCIdS: 0, Label: '*myROCK' [ '*myROCK' ], ASCTy: 0x3F (AAC) SubChId: 5, Language: Danish, StartCU: 84, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps UserApp 1/1: Label: '' [ '' ], UAType: 0x2 (SlideShow), X-PAD AppTy: 12, DSCTy: 0x3C (MOT), DG: 0, Data (2) [0C3C] 0x9096 *NOVA [ *NOVA ] ECC: 0xE1, Country: Denmark, PTy: Pop Music (static), Announcements: No AudioComponent (primary), SCIdS: 0, Label: '*NOVA' [ '*NOVA' ], ASCTy: 0x3F (AAC) SubChId: 6, Language: Danish, StartCU: 138, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps UserApp 1/1: Label: '' [ '' ], UAType: 0x2 (SlideShow), X-PAD AppTy: 12, DSCTy: 0x3C (MOT), DG: 0, Data (2) [0C3C] 0x9097 *Pop FM [ *Pop FM ] ECC: 0xE1, Country: Denmark, PTy: Pop Music (static), Announcements: No AudioComponent (primary), SCIdS: 0, Label: '*Pop FM' [ '*Pop FM' ], ASCTy: 0x3F (AAC) SubChId: 7, Language: Danish, StartCU: 192, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps UserApp 1/1: Label: '' [ '' ], UAType: 0x2 (SlideShow), X-PAD AppTy: 12, DSCTy: 0x3C (MOT), DG: 0, Data (2) [0C3C] 0x9098 *Radio Soft [ *Soft ] ECC: 0xE1, Country: Denmark, PTy: Easy Listening Music (static), Announcements: No AudioComponent (primary), SCIdS: 0, Label: '*Radio Soft' [ '*Soft' ], ASCTy: 0x3F (AAC) SubChId: 8, Language: Danish, StartCU: 246, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps UserApp 1/1: Label: '' [ '' ], UAType: 0x2 (SlideShow), X-PAD AppTy: 12, DSCTy: 0x3C (MOT), DG: 0, Data (2) [0C3C] 0x9099 *Radio 100 [ *R100 ] ECC: 0xE1, Country: Denmark, PTy: Pop Music (static), Announcements: No AudioComponent (primary), SCIdS: 0, Label: '*Radio 100' [ '*R100' ], ASCTy: 0x3F (AAC) SubChId: 9, Language: Danish, StartCU: 300, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps UserApp 1/1: Label: '' [ '' ], UAType: 0x2 (SlideShow), X-PAD AppTy: 12, DSCTy: 0x3C (MOT), DG: 0, Data (2) [0C3C] 0x909B *mix 7 [ *mix 7 ] ECC: 0xE1, Country: Denmark, PTy: Pop Music (static), Announcements: No AudioComponent (primary), SCIdS: 0, Label: '*mix 7' [ '*mix 7' ], ASCTy: 0x3F (AAC) SubChId: 11, Language: Danish, StartCU: 354, NumCU: 48, EEP 3-A, Coderate: 1/2, Bitrate: 64kbps UserApp 1/1: Label: '' [ '' ], UAType: 0x2 (SlideShow), X-PAD AppTy: 12, DSCTy: 0x3C (MOT), DG: 0, Data (2) [0C3C] 0x909C *Radio Vinyl [ *Vinyl ] ECC: 0xE1, Country: Denmark, PTy: Oldies Music (static), Announcements: No AudioComponent (primary), SCIdS: 0, Label: '*Radio Vinyl' [ '*Vinyl' ], ASCTy: 0x3F (AAC) SubChId: 12, Language: Danish, StartCU: 402, NumCU: 48, EEP 3-A, Coderate: 1/2, Bitrate: 64kbps UserApp 1/1: Label: '' [ '' ], UAType: 0x2 (SlideShow), X-PAD AppTy: 12, DSCTy: 0x3C (MOT), DG: 0, Data (2) [0C3C] 0x909D *PopFM 80'er [ *PopFM80 ] ECC: 0xE1, Country: Denmark, PTy: Pop Music (static), Announcements: No AudioComponent (primary), SCIdS: 0, Label: '*PopFM 80'er' [ '*PopFM80' ], ASCTy: 0x3F (AAC) SubChId: 13, Language: Danish, StartCU: 450, NumCU: 48, EEP 3-A, Coderate: 1/2, Bitrate: 64kbps UserApp 1/1: Label: '' [ '' ], UAType: 0x2 (SlideShow), X-PAD AppTy: 12, DSCTy: 0x3C (MOT), DG: 0, Data (2) [0C3C] 0x909E *PopFM 90'er [ *PopFM90 ] ECC: 0xE1, Country: Denmark, PTy: Pop Music (static), Announcements: No AudioComponent (primary), SCIdS: 0, Label: '*PopFM 90'er' [ '*PopFM90' ], ASCTy: 0x3F (AAC) SubChId: 10, Language: Danish, StartCU: 498, NumCU: 48, EEP 3-A, Coderate: 1/2, Bitrate: 64kbps UserApp 1/1: Label: '' [ '' ], UAType: 0x2 (SlideShow), X-PAD AppTy: 12, DSCTy: 0x3C (MOT), DG: 0, Data (2) [0C3C] 0x90A0 _PodRadio [ PodRadio ] ECC: 0xE1, Country: Denmark, PTy: N/A, Announcements: No AudioComponent (primary), SCIdS: 0, Label: '_PodRadio' [ 'PodRadio' ], ASCTy: 0x3F (AAC) SubChId: 19, Language: Danish, StartCU: 756, NumCU: 30, EEP 3-A, Coderate: 1/2, Bitrate: 40kbps UserApp 1/1: Label: '' [ '' ], UAType: 0x2 (SlideShow), X-PAD AppTy: 12, DSCTy: 0x3C (MOT), DG: 0, Data (2) [0C3C] 0x90AB RADIO MARS [ RDIOMARS ] ECC: 0xE1, Country: Denmark, PTy: Pop Music (static), Announcements: No AudioComponent (primary), SCIdS: 0, Label: 'RADIO MARS' [ 'RDIOMARS' ], ASCTy: 0x3F (AAC) SubChId: 3, Language: Danish, StartCU: 786, NumCU: 48, EEP 3-A, Coderate: 1/2, Bitrate: 64kbps UserApp 1/1: Label: '' [ '' ], UAType: 0x2 (SlideShow), X-PAD AppTy: 12, DSCTy: 0x3C (MOT), DG: 0, Data (2) [0C3C] 0x92F1 Skala.fm [ Skala.fm ] ECC: 0xE1, Country: Denmark, PTy: Pop Music (static), Announcements: No AudioComponent (primary), SCIdS: 0, Label: 'Skala.fm' [ 'Skala.fm' ], ASCTy: 0x3F (AAC) SubChId: 18, Language: Danish, StartCU: 654, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps UserApp 1/1: Label: '' [ '' ], UAType: 0x2 (SlideShow), X-PAD AppTy: 12, DSCTy: 0x3C (MOT), DG: 0, Data (2) [0C3C] 0x9D10 Classic [ Classic ] ECC: 0xE1, Country: Denmark, PTy: Pop Music (static), Announcements: No AudioComponent (primary), SCIdS: 0, Label: 'Classic' [ 'Classic' ], ASCTy: 0x3F (AAC) SubChId: 16, Language: Danish, StartCU: 546, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps UserApp 1/1: Label: '' [ '' ], UAType: 0x2 (SlideShow), X-PAD AppTy: 12, DSCTy: 0x3C (MOT), DG: 0, Data (2) [0C3C] 0x9DFA VLR [ VLR ] ECC: 0xE1, Country: Denmark, PTy: Pop Music (static), Announcements: No AudioComponent (primary), SCIdS: 0, Label: 'VLR' [ 'VLR' ], ASCTy: 0x3F (AAC) SubChId: 15, Language: Danish, StartCU: 708, NumCU: 48, EEP 3-A, Coderate: 1/2, Bitrate: 64kbps UserApp 1/1: Label: '' [ '' ], UAType: 0x2 (SlideShow), X-PAD AppTy: 12, DSCTy: 0x3C (MOT), DG: 0, Data (2) [0C3C] 0x9E7F Classic Rock [ Cl Rock ] ECC: 0xE1, Country: Denmark, PTy: Rock Music (static), Announcements: No AudioComponent (primary), SCIdS: 0, Label: 'Classic Rock' [ 'Cl Rock' ], ASCTy: 0x3F (AAC) SubChId: 17, Language: Danish, StartCU: 600, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps UserApp 1/1: Label: '' [ '' ], UAType: 0x2 (SlideShow), X-PAD AppTy: 12, DSCTy: 0x3C (MOT), DG: 0, Data (2) [0C3C]
| Dateianhänge: |
1722.jpg [ 7.71 KiB | 2282-mal betrachtet ]
