Aktuelle Zeit: Mo 12. Okt 2026, 18:39
Ein neues Thema erstellen Auf das Thema antworten  [ 13 Beiträge ]  Gehe zu Seite 1, 2  Nächste
BeitragVerfasst: So 31. Aug 2025, 21:27
Sendestart: 18.12.2025
Sendestandorte:
- Brilon/Allenberg (5 kW; TII 60-16)
- Dortmund/Florianturm (6 kW; TII 60-13)
- Ederkopf (2 kW; TII 60-18)
- Hagen-Eilpe (5 kW; TII 60-14)
- Herscheid/Waldberg (6 kW; TII 60-12)
- Hochsauerland/Hunau (4 kW; TII 60-17)
- Meschede/Fernmeldeturm (2,5 kW; TII 60-15)
- Siegen-Süd (3,5 kW; TII 60-19)
Programme:
- Metropol FM
Lokalsender:
- Antenne Unna
- ENNEPE RUHR
- Hellweg Radio
- Lippewelle Hamm
- Radio 91.2
- Radio Bochum
- Radio Hagen
- Radio MK
- Radio Sauerland
- Radio Siegen
=> Vergebene Plätze 11/16
Aktuelle Konfiguration:
Code:
Ensemble:
0x1004 NRW2_2_SWfDo [ NRW2_2 ] ECC: 0xE0, UTC 60 min, INT: 1, alarm announcements: 0
Services (11):
0x102B Metropol FM [ Metropol ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: No
AudioComponent (primary), SCIdS: 0, Label: 'Metropol FM' [ 'Metropol' ], ASCTy: 0x3F (AAC)
      SubChId: 12, Language: Unknown/NA, StartCU: 594, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps
0xD47E Antenne Unna [ Ant Unna ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [03]
AudioComponent (primary), SCIdS: 0, Label: 'Antenne Unna' [ 'Ant Unna' ], ASCTy: 0x3F (AAC)
      SubChId: 9, Language: Unknown/NA, StartCU: 486, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps
0xD498 Radio Sauerland [ Sauerlnd ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [09]
AudioComponent (primary), SCIdS: 0, Label: 'Radio Sauerland' [ 'Sauerlnd' ], ASCTy: 0x3F (AAC)
      SubChId: 6, Language: Unknown/NA, StartCU: 270, NumCU: 108, EEP 1-A, Coderate: 1/4, Bitrate: 72kbps
0xD57D Radio Bochum [ Bochum ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [08]
AudioComponent (primary), SCIdS: 0, Label: 'Radio Bochum' [ 'Bochum' ], ASCTy: 0x3F (AAC)
0xD79C Radio MK [ Radio MK ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [01]
AudioComponent (primary), SCIdS: 0, Label: 'Radio MK' [ 'Radio MK' ], ASCTy: 0x3F (AAC)
      SubChId: 10, Language: Unknown/NA, StartCU: 540, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps
0xD79D Hellweg Radio [ Hellweg ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [07]
AudioComponent (primary), SCIdS: 0, Label: 'Hellweg Radio' [ 'Hellweg ' ], ASCTy: 0x3F (AAC)
      SubChId: 8, Language: Unknown/NA, StartCU: 432, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps
0xDA58 ENNEPE RUHR [ EN RUHR ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [04]
AudioComponent (primary), SCIdS: 0, Label: 'ENNEPE RUHR' [ 'EN RUHR' ], ASCTy: 0x3F (AAC)
      SubChId: 3, Language: Unknown/NA, StartCU: 108, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps
0xDA7B Lippewelle Hamm [ Lippewel ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [02]
AudioComponent (primary), SCIdS: 0, Label: 'Lippewelle Hamm' [ 'Lippewel' ], ASCTy: 0x3F (AAC)
0xDB9B Radio 91.2 [ Radio912 ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [0A]
AudioComponent (primary), SCIdS: 0, Label: 'Radio 91.2' [ 'Radio912' ], ASCTy: 0x3F (AAC)
      SubChId: 2, Language: Unknown/NA, StartCU: 54, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps
0xDB9D RADIO SIEGEN [ SIEGEN ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [0B]
AudioComponent (primary), SCIdS: 0, Label: 'RADIO SIEGEN' [ 'SIEGEN' ], ASCTy: 0x3F (AAC)
      SubChId: 7, Language: Unknown/NA, StartCU: 378, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps
0xDC99 Radio Hagen [ Radio Ha ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [06]
AudioComponent (primary), SCIdS: 0, Label: 'Radio Hagen' [ 'Radio Ha' ], ASCTy: 0x3F (AAC)
(Stand: 11.05.2026)
BeitragVerfasst: Do 11. Dez 2025, 19:10
Hagen hat seine DAB-Antenne erhalten, jedoch wurde dort offensichtlich eine provisorische Antenne installiert, auf der Plattform unterhalb von DVB-T und UKW.
Gemäß Koordinierung und EMF-Eintrag, sollte die DAB-Antenne eigentlich oben an die Spitze über die DVB-T-Antennen. Der Platz wäre auch vorhanden.
Nur scheint es irgendwelche unvorhergesehenen Probleme gegeben zu haben, sodass kurzfristig umgeplant wurde.
In Schöppingen war damals die Steigleiter defekt, was die Installation verzögerte und in einer provisorischen Lösung resultierte. Gründe was in Hagen schiefgelaufen ist, sind mir noch nicht bekannt.
Theoretisch müsste in den kommenden Tagen die Standortbescheinigung noch für die provisorische Antenne aktualisiert werden, damit Hagen so auf Sendung gehen kann.
Das Dipol dürfte grob Richtung 0-10° zeigen auf ca. 70m, abwarten was der EMF-Eintrag angeben wird. Und durch den Beton geht nach hinten relativ wenig raus, wobei der Riegerberg nach Süden sowieso keine sonderlich gute Reichweite hat.
Hagen_provDAB-1.jpg [ 4.92 MiB | 5350-mal betrachtet ]
Hagen_provDAB-2.jpg [ 4.88 MiB | 5350-mal betrachtet ]
BeitragVerfasst: Do 18. Dez 2025, 12:09
Ebenfalls gestartet
Code:
Ensemble:
Services (11):
0x149C ENNEPE RUHR [ EN RUHR ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [03]
      SubChId: 3, Language: Unknown/NA, StartCU: 144, NumCU: 72, EEP 3-A, Coderate: 1/2, Bitrate: 96kbps
0x159C Radio Hagen [ Radio Ha ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [04]
      SubChId: 4, Language: Unknown/NA, StartCU: 216, NumCU: 72, EEP 3-A, Coderate: 1/2, Bitrate: 96kbps
0x169C Lippewelle Hamm [ Lippewel ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [05]
      SubChId: 5, Language: Unknown/NA, StartCU: 288, NumCU: 72, EEP 3-A, Coderate: 1/2, Bitrate: 96kbps
0x179C Radio Sauerland [ Sauerlnd ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [06]
      SubChId: 6, Language: Unknown/NA, StartCU: 360, NumCU: 108, EEP 1-A, Coderate: 1/4, Bitrate: 72kbps
0x189C Radio Siegen [ RaSiegen ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [07]
AudioComponent (primary), SCIdS: 0, Label: 'Radio Siegen' [ 'RaSiegen' ], ASCTy: 0x3F (AAC)
      SubChId: 7, Language: Unknown/NA, StartCU: 468, NumCU: 108, EEP 1-A, Coderate: 1/4, Bitrate: 72kbps
0x199C Hellweg Radio [ Hellweg ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [08]
      SubChId: 8, Language: Unknown/NA, StartCU: 576, NumCU: 72, EEP 3-A, Coderate: 1/2, Bitrate: 96kbps
0x1A9C Antenne Unna [ Ant Unna ] ECC: 0xE0, Country: Germany, PTy: Current Affairs (static), Announcements: Traffic News, Cluster IDs [0A]
      SubChId: 9, Language: Unknown/NA, StartCU: 648, NumCU: 72, EEP 3-A, Coderate: 1/2, Bitrate: 96kbps
0x1B9C Radio MK [ Radio MK ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [09]
      SubChId: 10, Language: Unknown/NA, StartCU: 720, NumCU: 72, EEP 3-A, Coderate: 1/2, Bitrate: 96kbps
0x1C9C Radio Vest [ Vest ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [0B]
AudioComponent (primary), SCIdS: 0, Label: 'Radio Vest' [ 'Vest' ], ASCTy: 0x3F (AAC)
      SubChId: 11, Language: Unknown/NA, StartCU: 792, NumCU: 72, EEP 3-A, Coderate: 1/2, Bitrate: 96kbps
0x1D9B Radio Bochum [ Bochum ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [01]
      SubChId: 1, Language: Unknown/NA, StartCU: 0, NumCU: 72, EEP 3-A, Coderate: 1/2, Bitrate: 96kbps
0x1E9B Radio 91,2 [ Radio912 ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [02]
AudioComponent (primary), SCIdS: 0, Label: 'Radio 91,2' [ 'Radio912' ], ASCTy: 0x3F (AAC)
      SubChId: 2, Language: Unknown/NA, StartCU: 72, NumCU: 72, EEP 3-A, Coderate: 1/2, Bitrate: 96kbps
BeitragVerfasst: Do 18. Dez 2025, 16:30
Alle Programme bis auf Radio Sauerland und Radio Siegen senden nun mit 96 kbps.
Sauerland und Siegen dagegen mit EEP-1A, bis Meschede und Ederkopf im Januar aufgeschaltet werden.
BeitragVerfasst: Do 18. Dez 2025, 20:10
* Zwischenstand zu den Zusatzdiensten *
- Antenne Unna: DL ja; DL+ ja; SLS ja
- ENNEPE RUHR: DL ja; DL+ ja; SLS ja
- Hellweg Radio: DL nein; DL+ nein; SLS ja
- Lippewelle Hamm: DL nein; DL+ nein; SLS ja
- Metropol FM: DL ja; DL+ ja; SLS ja
- Radio 91,2: DL ja; DL+ ja; SLS ja
- Radio Bochum: DL ja ; DL+ ja; SLS ja
- Radio Hagen: DL ja ; DL+ ja; SLS ja
- Radio MK: DL nein; DL+ nein; SLS ja
- Radio Sauerland: DL ja ; DL+ ja; SLS ja
- Radio Siegen: DL ja; DL+ ja; SLS ja
34.jpg [ 6.84 KiB | 4596-mal betrachtet ]
EN RUHR (1).JPG [ 20.16 KiB | 4596-mal betrachtet ]
11.PNG [ 7.83 KiB | 4596-mal betrachtet ]
11.PNG [ 8.11 KiB | 4596-mal betrachtet ]
44.JPG [ 7.61 KiB | 4596-mal betrachtet ]
11.PNG [ 7.51 KiB | 4596-mal betrachtet ]
12.PNG [ 5.56 KiB | 4597-mal betrachtet ]
Bochum.JPG [ 16.96 KiB | 5012-mal betrachtet ]
Radio_Ha.JPG [ 16.47 KiB | 5012-mal betrachtet ]
Sauerlnd.JPG [ 17.81 KiB | 5012-mal betrachtet ]
BeitragVerfasst: Do 5. Feb 2026, 17:13
- Update -
Label: "Radio Siegen" -> "RADIO SIEGEN"
Short: "Siegen" -> "SIEGEN"
EEP: 1-A -> 3-A
Code:
0x189C RADIO SIEGEN [ SIEGEN ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [0B]
      SubChId: 7, Language: Unknown/NA, StartCU: 468, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps
BeitragVerfasst: Do 12. Feb 2026, 11:58
Bochum, Hellweg und Siegen wurden nun auch auf die neue Zuführung umgestellt:
Code:
      SubChId: 8, Language: Unknown/NA, StartCU: 522, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps
BeitragVerfasst: Do 19. Feb 2026, 14:36
Hagen, MK und Sauerland wurden nun auch auf die neue Zuführung umgestellt:
Code:
      SubChId: 4, Language: Unknown/NA, StartCU: 198, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps
      SubChId: 10, Language: Unknown/NA, StartCU: 612, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps
      SubChId: 6, Language: Unknown/NA, StartCU: 324, NumCU: 108, EEP 1-A, Coderate: 1/4, Bitrate: 72kbps
BeitragVerfasst: Di 3. Mär 2026, 18:25
Antenne Unna und Ennepe Ruhr wurden heute umgestellt:
Code:
      SubChId: 9, Language: Unknown/NA, StartCU: 522, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps
      SubChId: 3, Language: Unknown/NA, StartCU: 126, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps
BeitragVerfasst: Fr 6. Mär 2026, 14:19
Radio 91.2 wurde gestern umgestellt
Code:
