Aktuelle Zeit: Sa 18. Jul 2026, 01:17
Ein neues Thema erstellen Auf das Thema antworten  [ 28 Beiträge ]  Gehe zu Seite 1, 2, 3  Nächste
BeitragVerfasst: Do 31. Jul 2025, 22:22
Sendestart: 18.12.2025
Sendestandorte:
- Düsseldorf/Rheinturm (5 kW; TII 60-08)
- Wuppertal-Küllenhahn (5 kW; TII 60-09)
Programme:
- DOMRADIO
- Metropol FM
- StreamD
- *Radio MusicStar
Lokalsender:
- ANTENNE D
- NEWS 89.4
- RADIO 90.1 MG
- RADIO NEANDERTAL
- RADIO RSG
- RADIO WUPPERTAL
- WELLE NR
=> Vergebene Plätze 11/16
Aktuelle Konfiguration:
Code:
Ensemble:
0x1002 NRW2_6_DWM [ NRW2_6 ] ECC: 0xE0, UTC 120 min, INT: 1, alarm announcements: 0
Services (11):
0x102B Metropol FM [ Metropol ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: No
AudioComponent (primary), SCIdS: 0, Label: 'Metropol FM' [ 'Metropol' ], ASCTy: 0x3F (AAC)
      SubChId: 8, Language: Unknown/NA, StartCU: 378, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps
0x109D DOMRADIO [ DOMRADIO ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: No
AudioComponent (primary), SCIdS: 0, Label: 'DOMRADIO' [ 'DOMRADIO' ], ASCTy: 0x3F (AAC)
      SubChId: 10, Language: Unknown/NA, StartCU: 486, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps
0x1D9E StreamD [ StreamD ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: No
AudioComponent (primary), SCIdS: 0, Label: 'StreamD' [ 'StreamD' ], ASCTy: 0x3F (AAC)
      SubChId: 9, Language: Unknown/NA, StartCU: 432, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps
0x1E9E *Radio MusicStar [ *RMStar ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: No
AudioComponent (primary), SCIdS: 0, Label: '*Radio MusicStar' [ '*RMStar' ], ASCTy: 0x3F (AAC)
      SubChId: 13, Language: Unknown/NA, StartCU: 540, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps
0xD07B RADIO WUPPERTAL [ R WUPPER ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [07]
AudioComponent (primary), SCIdS: 0, Label: 'RADIO WUPPERTAL' [ 'R WUPPER' ], ASCTy: 0x3F (AAC)
      SubChId: 7, Language: Unknown/NA, StartCU: 324, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps
0xD09C RADIO 90.1 MG [ 90.1 MG ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [09]
AudioComponent (primary), SCIdS: 0, Label: 'RADIO 90.1 MG' [ '90.1 MG' ], ASCTy: 0x3F (AAC)
0xD09E ANTENNE D [ ANTENNE ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [03]
AudioComponent (primary), SCIdS: 0, Label: 'ANTENNE D' [ 'ANTENNE ' ], ASCTy: 0x3F (AAC)
0xD359 RADIO NEANDERTAL [ NEANDER ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [06]
AudioComponent (primary), SCIdS: 0, Label: 'RADIO NEANDERTAL' [ 'NEANDER' ], ASCTy: 0x3F (AAC)
      SubChId: 3, Language: Unknown/NA, StartCU: 108, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps
0xD47D RADIO RSG [ RSG ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [02]
AudioComponent (primary), SCIdS: 0, Label: 'RADIO RSG' [ 'RSG' ], ASCTy: 0x3F (AAC)
      SubChId: 6, Language: Unknown/NA, StartCU: 270, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps
0xDB98 WELLE NR [ WELLE NR ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [08]
AudioComponent (primary), SCIdS: 0, Label: 'WELLE NR' [ 'WELLE NR' ], ASCTy: 0x3F (AAC)
      SubChId: 2, Language: Unknown/NA, StartCU: 54, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps
0xDD9F NEWS 89.4 [ NEWS89.4 ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [0A]
AudioComponent (primary), SCIdS: 0, Label: 'NEWS 89.4' [ 'NEWS89.4' ], ASCTy: 0x3F (AAC)
(Stand: 31.03.2026)
BeitragVerfasst: Di 28. Okt 2025, 23:50
Nettetal und der Kreis Heinsberg besonders Selfkant wird der Empfang schlecht oder kaum funktionieren.....
Da muss noch was passieren aber ob man zwischen Heinsberg und Selfkant überhaupt Interesse hat an Radio Wuppertal und Antenne Düsseldorf kann bezweifelt werden da hört man BRF und 100,5 Das Hitradio und der Köln Mux 8B wird dort gut zu empfangen sein und man fühlt sich Aachen sowieso näher als Düsseldorf.....
BeitragVerfasst: Fr 31. Okt 2025, 17:20
Martin hat geschrieben:
In Nettetal dürfte man eher Interesse an Welle Niederrhein haben.
Aber du hast Recht, mit 5 Kw von Düsseldorf, dass dürfte echt schwierig werden.
Warum nutzt man nicht einfach den Turm in Viersen Süchteln, sowie der WDR es macht mit 1 Kw Leistung, da stört man die Niederländer nicht wirklich.
Brüggen und Niederkrüchten dürften die gleichen Probleme haben, wie Nettetal.
BeitragVerfasst: Fr 31. Okt 2025, 17:53
Es gibt keine Probleme mit geeigneten Standorten oder Einsprüchen aus dem Ausland.
Es liegt schlicht daran, dass man vorerst kein Interesse an einer besseren Versorgung hat.
BeitragVerfasst: Mi 12. Nov 2025, 20:23
Auch StreamD vermeldet nun einen Starttermin für den 12D D/W/MG.
Demnach ist ein Start am 1.2.26 geplant.
Neben der Altstadtwelle immerhin ein zweiterer kleinerer Anbieter, der es versuchen möchte.
Seien ihnen alle Daumen gedrückt, um abseits des Mainstreams bestehen zu können.
https://streamd.de/
BeitragVerfasst: Fr 14. Nov 2025, 21:41
Von der Musikfarbe R&B Black Musik Disco Classics DJ Mitschnitte Ibiza Café del Mar Musik Live Events aus Clubs usw.
Das hört sich ja total interessant an *bravo*
In den Niederlanden scheint das aber gut anzukommen da gibt es so einige Programme die in diese Richtung einschlagen aber entweder hat sich das hier noch keiner getraut oder die Deutschen haben einen anderen Musikgeschmack :lol:
Wobei es ja in Potsdam-Berlin "BHeins" ja auch schon über viele Jahre gut funktioniert und da wird über UKW und DAB+ gesendet :roll:
Endlich mal was anderes *plus1*
stream-d.jpg [ 163.53 KiB | 4102-mal betrachtet ]
BeitragVerfasst: Fr 21. Nov 2025, 19:53
Die Seite ukwtv.de meldet, dass auch Nius mit dabei ist.
Um Gottes Willen.
BeitragVerfasst: Fr 21. Nov 2025, 20:17
Das ist schon lange klar, dass NIUS in NRW senden will.
Es ist bislang nur weiterhin nicht klar, ob das wirklich in den Regionalmuxen sein wird oder im 9D.
ukwtv.de spekuliert da auch nur.
BeitragVerfasst: Do 18. Dez 2025, 20:38
Läuft selbstverständlich auch:
Code:
Ensemble:
0x1002 NRW2_6_DWM [ NRW2_6 ] ECC: 0xE0, UTC 60 min, INT: 1, alarm announcements: 0
Services (8):
0x169E ANTENNE D [ ANTENNE ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [01]
      SubChId: 1, Language: Unknown/NA, StartCU: 0, NumCU: 72, EEP 3-A, Coderate: 1/2, Bitrate: 96kbps
0x179E WELLE NR [ WELLE NR ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [02]
      SubChId: 2, Language: Unknown/NA, StartCU: 72, NumCU: 72, EEP 3-A, Coderate: 1/2, Bitrate: 96kbps
0x189E RADIO NEANDERTAL [ NEANDER ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [03]
      SubChId: 3, Language: Unknown/NA, StartCU: 144, NumCU: 72, EEP 3-A, Coderate: 1/2, Bitrate: 96kbps
0x199E RADIO 90.1 MG [ 90.1 MG ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [04]
      SubChId: 4, Language: Unknown/NA, StartCU: 216, NumCU: 72, EEP 3-A, Coderate: 1/2, Bitrate: 96kbps
0x1A9E NEWS 89.4 [ NEWS89.4 ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [05]
      SubChId: 5, Language: Unknown/NA, StartCU: 288, NumCU: 72, EEP 3-A, Coderate: 1/2, Bitrate: 96kbps
0x1B9E RADIO RSG [ RSG ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: Traffic News, Cluster IDs [06]
      SubChId: 6, Language: Unknown/NA, StartCU: 360, NumCU: 72, EEP 3-A, Coderate: 1/2, Bitrate: 96kbps
0x1C9B DOMRADIO [ DOMRADIO ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: No
      SubChId: 10, Language: Unknown/NA, StartCU: 504, NumCU: 72, EEP 3-A, Coderate: 1/2, Bitrate: 96kbps
0x1C9E RADIO WUPPERTAL [ R WUPPER ] ECC: 0xE0, Country: Germany, PTy: Current Affairs (static), Announcements: Traffic News, Cluster IDs [07]
      SubChId: 7, Language: Unknown/NA, StartCU: 432, NumCU: 72, EEP 3-A, Coderate: 1/2, Bitrate: 96kbps
BeitragVerfasst: Fr 19. Dez 2025, 11:02
* Zwischenstand zu den Zusatzdiensten *
- ANTENNE D: DL ja; DL+ ja; SLS ja
- DOMRADIO: DL ja; DL+ ja; SLS ja
- NEWS 89.4: DL ja; DL+ ja; SLS ja
- RADIO 90.1 MG: DL ja; DL+ ja; SLS ja
- RADIO NEANDERTAL: DL ja ; DL+ ja; SLS ja
- RADIO RSG: DL ja; DL+ ja; SLS ja
- RADIO WUPPERTAL: DL ja; DL+ ja; SLS ja
- WELLE NR: DL ja; DL+ ja; SLS ja
88.JPG [ 40.04 KiB | 2228-mal betrachtet ]
ANTENNE_D.JPG [ 23.9 KiB | 3017-mal betrachtet ]
NEWS89.4.JPG [ 18.88 KiB | 3017-mal betrachtet ]
90.1_MG.JPG [ 22.04 KiB | 3017-mal betrachtet ]
NEANDER.JPG [ 25.82 KiB | 3017-mal betrachtet ]
RSG.JPG [ 28.43 KiB | 3017-mal betrachtet ]
R_WUPPER.JPG [ 20.03 KiB | 3017-mal betrachtet ]
WELLE_NR.JPG [ 16.49 KiB | 3017-mal betrachtet ]
