Aktuelle Zeit: So 1. Jun 2025, 02:12
Ein neues Thema erstellen Auf das Thema antworten  [ 829 Beiträge ]  Gehe zu Seite Vorherige  1 ... 79, 80, 81, 82, 83
BeitragVerfasst: Fr 9. Mai 2025, 11:35
Das einzige PC Programm das den 6C Leipzig bei mir abspielt. Slideshow, ein Begrüßungstext und 96kBit AAC-LC werden gesendet. Im SPI sehe ich nichts vom neuen Programm.
sls1.jpg [ 3.54 KiB | 1113-mal betrachtet ]
Screenshot 2025-05-09 112729.png [ 87.05 KiB | 1113-mal betrachtet ]
Zugteilt: 642CU (74,3%)
0xD123 DAB+ Leipzig [ DABLpz ] ECC: 0xE0, UTC 120 min, INT: 1, alarm announcements: 0
Services (11):
0x1014 egoFM [ egoFM ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: No
AudioComponent (primary), SCIdS: 0, Label: 'egoFM' [ 'egoFM' ], ASCTy: 0x3F (AAC)
SubChId: 1, Language: Unknown/NA, StartCU: 66, NumCU: 60, EEP 3-A, Coderate: 1/2, Bitrate: 80kbps
0x10C6 Leipzig 2 [ Leipzig2 ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: No
AudioComponent (primary), SCIdS: 0, Label: 'Leipzig 2' [ 'Leipzig2' ], ASCTy: 0x3F (AAC)
SubChId: 5, Language: Unknown/NA, StartCU: 312, NumCU: 66, EEP 3-A, Coderate: 1/2, Bitrate: 88kbps
0x10C9 mephisto 97.6 [ mephisto ] ECC: 0xE0, Country: Germany, PTy: Culture (static), Announcements: No
AudioComponent (primary), SCIdS: 0, Label: 'mephisto 97.6' [ 'mephisto' ], ASCTy: 0x3F (AAC)
SubChId: 4, Language: Unknown/NA, StartCU: 252, NumCU: 60, EEP 3-A, Coderate: 1/2, Bitrate: 80kbps
0x10CA SACHSEN eins L [ SACHSEN ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: No
AudioComponent (primary), SCIdS: 0, Label: 'SACHSEN eins L' [ 'SACHSEN' ], ASCTy: 0x3F (AAC)
SubChId: 2, Language: Unknown/NA, StartCU: 126, NumCU: 60, EEP 3-A, Coderate: 1/2, Bitrate: 80kbps
0x10CB SchlagerPlanet [ Schlager ] ECC: 0xE0, Country: Germany, PTy: Easy Listening Music (static), Announcements: No
AudioComponent (primary), SCIdS: 0, Label: 'SchlagerPlanet' [ 'Schlager' ], ASCTy: 0x3F (AAC)
SubChId: 7, Language: Unknown/NA, StartCU: 444, NumCU: 60, EEP 3-A, Coderate: 1/2, Bitrate: 80kbps
0x141F MEGA 80s [ MEGA 80s ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: No
AudioComponent (primary), SCIdS: 0, Label: 'MEGA 80s' [ 'MEGA 80s' ], ASCTy: 0x3F (AAC)
SubChId: 3, Language: Unknown/NA, StartCU: 186, NumCU: 66, EEP 3-A, Coderate: 1/2, Bitrate: 88kbps
0x14C8 BOLLERWAGEN [ BOLLER ] ECC: 0xE0, Country: Germany, PTy: Pop Music (static), Announcements: No
AudioComponent (primary), SCIdS: 0, Label: 'BOLLERWAGEN' [ 'BOLLER' ], ASCTy: 0x3F (AAC)
SubChId: 10, Language: Unknown/NA, StartCU: 504, NumCU: 54, EEP 3-A, Coderate: 1/2, Bitrate: 72kbps
0x16CE WGT Event [ WGTEvent ] ECC: 0xE0, Country: Germany, PTy: Culture (static), Announcements: No
AudioComponent (primary), SCIdS: 0, Label: 'WGT Event' [ 'WGTEvent' ], ASCTy: 0x3F (AAC)
SubChId: 30, Language: German, StartCU: 570, NumCU: 72, EEP 3-A, Coderate: 1/2, Bitrate: 96kbps
0x1AC5 apollo radio))) [ apollo ] ECC: 0xE0, Country: Germany, PTy: Light Classical (static), Announcements: No
AudioComponent (primary), SCIdS: 0, Label: 'apollo radio)))' [ 'apollo' ], ASCTy: 0x3F (AAC)
SubChId: 0, Language: Unknown/NA, StartCU: 0, NumCU: 66, EEP 3-A, Coderate: 1/2, Bitrate: 88kbps
0xD3DA ROCKLAND [ ROCKLAND ] ECC: 0xE0, Country: Germany, PTy: Rock Music (static), Announcements: No
AudioComponent (primary), SCIdS: 0, Label: 'ROCKLAND' [ 'ROCKLAND' ], ASCTy: 0x3F (AAC)
SubChId: 6, Language: Unknown/NA, StartCU: 378, NumCU: 66, EEP 3-A, Coderate: 1/2, Bitrate: 88kbps
0xE0D0D123 SPI [ SPI ]
DataComponent (MSC Packet Data) (primary), SCIdS: 0, SCId: 10, Language: Unknown/NA, Label: 'SPI' [ 'SPI' ], DSCTy: 0x3C (MOT), DG: 0, PacketAddr: 1
SubChId: 20, Language: Unknown/NA, StartCU: 558, NumCU: 12, EEP 3-A [FEC scheme applied], Coderate: 1/2
Zuletzt geändert von pomnitz26 am Mo 12. Mai 2025, 13:02, insgesamt 1-mal geändert.
BeitragVerfasst: Fr 9. Mai 2025, 13:33
AAC-LC ist interessant. Nutzt man das möglicherweise auch gleich als Zuführung für die UKW Funzel? Da wäre HE-AAC nämlich ungeeignet.
So könnte man sich die doppelte Zuführung ganz einfach sparen.
BeitragVerfasst: Sa 10. Mai 2025, 18:48
Leider gibt es die Titelanzeige beim WGT Radio nur auf UKW, nicht aber auf DAB+.
Hätte da viel mehr Sinn gemacht.
BeitragVerfasst: Sa 10. Mai 2025, 20:53
Ein Video das mir gerade angezeigt wurde stellt das sehr schön dar.
https://youtu.be/tcyUd7eZwuM
Bei mir läuft es auf DAB+ recht gut, auf der 92,5 ist MDR Thüringen, Autoradios die noch die 92,6 heraus holen können haben dort recht schwach aber in sauberen Stereo SAW drauf.
BeitragVerfasst: Sa 10. Mai 2025, 22:41
Ja, das Video ist sogar von mir, dient auch als visuelle Dokumentation. Der TEF 6686 schafft es sogar, dieses absolut grauenvolle Wechsel-RDS weitgehend fehlerfrei darzustellen.
SAW hab ich auf 92,6 hier nie bekommen, höchstens mal bei Lokaltropo.
Im Leipziger Norden kann der die WGT Frequenz allerdings angreifen.
Schade, dass es keine weiteren DAB-Muxe aus Richtung Dessau/Magdeburg gibt, die man hier theortisch DXen könnte.
BeitragVerfasst: Mo 12. Mai 2025, 07:43
Das Gewandhausradio ist gestartet, dafür ist das WTG Radio stumm und ohne Audiokennung auf Sendung. Slideshow und Text samt kurzer Titelanzeige die dann sogar als DL+ gekennzeichnet wird gespeichert bleibt gibt es auch. Der Empfang ist wegen des NDR heute sehr schwach aber trotzdem ungestört. Im SPI ist das Programm mit aufgenommen worden, WTG Radio nicht.
https://www.gewandhausradio.de/empfang/
sls1_18.jpg [ 21.7 KiB | 731-mal betrachtet ]
Screenshot (23).png [ 121.47 KiB | 700-mal betrachtet ]
Belegt: 714 CU (82,6%), Frei: 150 CU (17,4%)
Audio: 702 CU (81,2%), Daten: 12 CU (1,4%)
Ensemble:
Services (12):
SubChId: 30, Language: German, StartCU: 642, NumCU: 72, EEP 3-A, Coderate: 1/2, Bitrate: 96kbps
0x17C2 Gewandhausradio [ Ghr ] ECC: 0xE0, Country: Germany, PTy: Serious Classical (static), Announcements: No
AudioComponent (primary), SCIdS: 0, Label: 'Gewandhausradio' [ 'Ghr' ], ASCTy: 0x3F (AAC)
SubChId: 11, Language: Unknown/NA, StartCU: 558, NumCU: 72, EEP 3-A, Coderate: 1/2, Bitrate: 96kbps
DataComponent (MSC Packet Data) (primary), SCIdS: 0, SCId: 11, Language: Unknown/NA, Label: 'SPI' [ 'SPI' ], DSCTy: 0x3C (MOT), DG: 0, PacketAddr: 1
SubChId: 20, Language: Unknown/NA, StartCU: 630, NumCU: 12, EEP 3-A [FEC scheme applied], Coderate: 1/2
Zuletzt geändert von pomnitz26 am Mo 12. Mai 2025, 13:06, insgesamt 4-mal geändert.
BeitragVerfasst: Mo 12. Mai 2025, 10:27
Hut ab, für die 96kbps ein richtig hochwertiger Klang, wenngleich ich bei diesem Sender deutlich mehr Bitrate erwartet hätte. Es ist so viel frei und so teuer ist dieser 2KW-Mux jetzt auch nicht.
Wenigstens LC-AAC wie beim WGT Radio wären drin gewesen.
BeitragVerfasst: Mo 12. Mai 2025, 12:14
Der Multiplex wurde nochmals überarbeitet. Das WTG Radio spielt wieder und die Programmkennungen wurden überarbeitet. Ich habe den Beitrag oben angepasst.
Vorher:
Zugeteilt: 702CU (81,3%)
Aktuell
Zugeteilt: 702CU (82,6%)
Zuletzt geändert von pomnitz26 am Mo 12. Mai 2025, 13:03, insgesamt 1-mal geändert.
BeitragVerfasst: Mo 12. Mai 2025, 12:16
Was für ein seltsames Shortlabel. Da weiß keiner, für was das stehen soll. Warum kommt niemand auf "Gwndhaus" oder "Gewandhs"?
